KTM 790 Adventure
Moderátoři: Fox13, Malý Venoušek
Re: KTM 790 Adventure
Příspěvek od jenik » stř črc 04, 2018 7:41 am
Příspěvek od jenik » stř črc 11, 2018 7:46 am
Příspěvek od jenik » stř zář 12, 2018 11:59 am
https://www.bennetts.co.uk/bikesocial/n ... ng-in-2019
"KTM say the Adventure’s tuning has been adapted for less top-end and more low and midrange performance than the pure road bike; the 790 Duke makes an honest 100bhp at the wheel, but it’s a relatively peaky motor with a dip in the torque curve between 4000 and 6000rpm (wheelie fans will note the 790 Duke isn’t a mono-monster; Yamaha’s MT-07 is easier to hoist). Re-tuning the Adventure for a more linear, midrange-rich delivery probably won’t involve major engine changes and will likely come from revised fuelling and ignition timing (although revised cam timing and a heavier crank aren’t out of the question). Expect around 90bhp at the wheel, possibly on longer gearing."
Příspěvek od jenik » úte lis 06, 2018 3:14 pm
https://www.youtube.com/watch?v=5UlOOwHQfU0
https://www.youtube.com/watch?v=FcaWymGduOs
Specification
Engine size 799cc
Engine type 2-cylinder, 4-stroke, DOHC Parallel twin
Frame type Chromium-molybdenum-steel frame using the engine as stressed element, powder coated
Fuel capacity 20 litres
Seat height 850mm
Bike weight 189kg
Front suspension WP-USD Ø 43 mm
Rear suspension WP shock absorber
Front brake 2 × radially mounted 4 piston caliper, brake disc Ø 320 mm
Rear brake 2 piston floating caliper, brake disc Ø 260 mm
Front tyre size 90/90-21"
Rear tyre size 150/70-18"
Příspěvek od jenik » stř lis 07, 2018 1:29 pm
je mi to trapne, ale musim rict, ze na prvni pohled skrze video mi projde KTM790A technologicky napred pred T7. I kdyz uvidime nazivo jak to bude. Nadrz tedy fakt udelali divne.
Příspěvek od jenik » čtv lis 08, 2018 8:44 am
Příspěvek od jenik » úte lis 13, 2018 8:26 am
Příspěvek od jenik » pon pro 10, 2018 9:01 am
Příspěvek od jenik » úte úno 12, 2019 9:59 am
Příspěvek od jenik » stř bře 13, 2019 7:46 am
Nebude tomu tlumici vadit ze je kousek nad katalyzatorem a vedle svodu?
Příspěvek od jenik » stř bře 13, 2019 2:23 pm
2019 KTM 790 Adventure R First Ride Review
https://www.motorcycle.com/manufacturer ... eview.html
Příspěvek od MotoTraveller » stř bře 13, 2019 5:52 pm
Řekl bych, že mu to určitě nebude prospívat. Ale je tam toho víc. Dole je hrozně široká + když se tam dají padáky tak bude ještě víc - I bez padáků si myslím, že bude problém pokud člověk vjede do kolejí. A to nemluvím o díře mezi chladičem a krytem motoru kam bude fest lítat bláto, protože přední blatník je zvednutý a bude problém ho vodtamtud dostat a nehledě na to, že je tam i klakson takže bude za chvíly jako koule bláta
Příspěvek od jenik » pát bře 15, 2019 9:59 am
Bude vedro?
Příspěvek od jenik » pon bře 25, 2019 7:50 am
Prvni majitel
https://www.motorkari.cz/motorka/?mid=120820
Na tomhle delat ventily... no asi na vsech novych motorkach uz to nebude tak jednoduche
Příspěvek od jenik » pon dub 15, 2019 6:28 am
Pristi rok se ocekava novy motor 2V 500ccm, vyrabet by se mel v Bajaj v Indii
