KTM 790 Adventure
Re: KTM 790 Adventure
https://www.bennetts.co.uk/bikesocial/n ... ng-in-2019
"KTM say the Adventure’s tuning has been adapted for less top-end and more low and midrange performance than the pure road bike; the 790 Duke makes an honest 100bhp at the wheel, but it’s a relatively peaky motor with a dip in the torque curve between 4000 and 6000rpm (wheelie fans will note the 790 Duke isn’t a mono-monster; Yamaha’s MT-07 is easier to hoist). Re-tuning the Adventure for a more linear, midrange-rich delivery probably won’t involve major engine changes and will likely come from revised fuelling and ignition timing (although revised cam timing and a heavier crank aren’t out of the question). Expect around 90bhp at the wheel, possibly on longer gearing."
https://www.youtube.com/watch?v=5UlOOwHQfU0
https://www.youtube.com/watch?v=FcaWymGduOs
Specification
Engine size 799cc
Engine type 2-cylinder, 4-stroke, DOHC Parallel twin
Frame type Chromium-molybdenum-steel frame using the engine as stressed element, powder coated
Fuel capacity 20 litres
Seat height 850mm
Bike weight 189kg
Front suspension WP-USD Ø 43 mm
Rear suspension WP shock absorber
Front brake 2 × radially mounted 4 piston caliper, brake disc Ø 320 mm
Rear brake 2 piston floating caliper, brake disc Ø 260 mm
Front tyre size 90/90-21"
Rear tyre size 150/70-18"
je mi to trapne, ale musim rict, ze na prvni pohled skrze video mi projde KTM790A technologicky napred pred T7. I kdyz uvidime nazivo jak to bude. Nadrz tedy fakt udelali divne.
Nebude tomu tlumici vadit ze je kousek nad katalyzatorem a vedle svodu?
2019 KTM 790 Adventure R First Ride Review
https://www.motorcycle.com/manufacturer ... eview.html
Řekl bych, že mu to určitě nebude prospívat. Ale je tam toho víc. Dole je hrozně široká + když se tam dají padáky tak bude ještě víc - I bez padáků si myslím, že bude problém pokud člověk vjede do kolejí. A to nemluvím o díře mezi chladičem a krytem motoru kam bude fest lítat bláto, protože přední blatník je zvednutý a bude problém ho vodtamtud dostat a nehledě na to, že je tam i klakson takže bude za chvíly jako koule bláta
Bude vedro?
Prvni majitel
https://www.motorkari.cz/motorka/?mid=120820
Na tomhle delat ventily... no asi na vsech novych motorkach uz to nebude tak jednoduche
Pristi rok se ocekava novy motor 2V 500ccm, vyrabet by se mel v Bajaj v Indii
